We did a self clean yesterday. Oven would not shut off when it was finished after several hours. Had to shut off Breaker Box in order to shut oven down. The Oven front panel went "blank" before shutting it down. Now, the lock lever will not unlock. This morning, the clock is back on the oven, and the oven turns on to bake with a temperature. It wouldn't do that last night when we turned the breaker back on. How do we get the oven door open? The lever only slides to the middle right. The lever is stuck on the left which is the "unlock" side, but still will not open, or move to the right; the "locked" positioned. So strange! :rolleyes: I have the original manual for the oven. Oven was new in 1993.
Hi Elizabeth,
What is going on with the indicator lights on the control panel if the power is "on"?
Does the oven clock is working?
Gene. Hi Gene Yes, the oven comes on with the clock working. The timer also works on the clock too! I just can't open the oven door nor move the latch over. I'm looking how to remove the oven door?? Any help is appreciated.
Hi Elizabeth, You have to remove the control panel and the latch cover (#6 on the break down diagram). Here are the break down diagrams for the Jenn Air oven Model W130Gene.
Did you get your door fixed by following the response given to you? Was the control panel accessable from the back of the oven, and if it was what did you do to it?
Thanks, LuLu
