Thank you for any help in advance. We just moved our two year old frigidaire front loading washer and now I'm regretting it. It fills just like normal, but then it won't start to agitate (or do anything else for that matter). Right after it finishes filling, then all five lights on the right hand panel flash and it beeps, it doesn't do anything else. Then after a few more minutes it all shuts down and you then have to empty the washer water by hand. Thanks again for reading this and any ideas are appreciated.
Perform the troubleshooting as described in the tech sheet located on the left hand side behind the front access panel.
Post the results.
