jenlow
#1 Posted : Monday, May 26, 2008 12:41:26 PM(UTC)
jenlow
Ice mamer and water dispenser work only whenm they want to. First had a clogged inlet screen, replaeced and ice worked, water worked. Water stopped, ice was working fine, now ice quit making. I have power to all solenoids when working dispenser button. Water pressure is good. Can a soleniod that has voltage, not work? I have taken them apart and cleaned the slides and all work when i run the 4 of them off the same plug. Could i have the plugs installed upside down? I dont think A/C current makes any diff does it???
THanks
SublimeMasterJW
#2 Posted : Monday, May 26, 2008 1:18:47 PM(UTC)
SublimeMasterJW
SublimeMasterJW attached the following image(s):
