I bought a beer fridge for the garage, and when I plug it in, it trips my GFI. I only have that plugged in, so I know it isn't the circuit. When I unplug the compressor, the light and fans work. Is the compressor bad, or could it be something else?
Just a suggestion. When I tried to run my compressor on a GFI circuit it blew everytime. The current it takes to initally start the compressor draws too much current. I run it on a different circuit for lighting w/o GFI protection and it works fine. May want to try a different circuit with proper breaker amperage for the appliance you wish to run. Hope it helps. Lee
Great suggestion. If that does not work let us know so we can help you
