kerley
#1 Posted : Monday, March 15, 2010 5:09:48 AM(UTC)
kerley
I have a whirlpool duet that does not shut the water off during or after the cycle and was wondering if the water inlet valve could be the culprit
magician59
#2 Posted : Monday, March 15, 2010 10:21:37 AM(UTC)
magician59
Try to fill it (You don't need to use clothes for this), and when it starts to wash, unplug the washer. If the water stops, it's probably something like a clogged or partially restricted pressure hose, not allowing the pressure switch to be satisfied. If the water continues to come in, replace the inlet valve.
