Davidf2010
#1 Posted : Sunday, March 14, 2010 12:04:23 PM(UTC)
Davidf2010
The temperature control inside the refrig side of my side by side Kitchenaid doesn't work. No power, no LEDs but the light bulb in the same housing works and the rest of the refrigerator works. Safe to assume its the circuit board in the temperature control housing thats bad?
Davidf2010
#2 Posted : Wednesday, August 11, 2010 11:47:08 AM(UTC)
Davidf2010
Anyone with any tips on this problem?
TIA
#3 Posted : Thursday, August 12, 2010 2:45:58 AM(UTC)
Replacement parts for WHIRLPOOL KSCS25FKSS01 Refrigerator | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202214447.pdf
Here is a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/98b42774e060d1dd85256b58006780e1/$FILE/4317290A.pdf
This is a hard one to trouble shoot as it could be the main control board or the display board.
Check the display board for any signs of overheating or a cracked track on the board.
Check that you have 12 volts DC on P2 pins 2 to 3 on the display board.
If not then odds are high that the main control board is shot.
If you have the 12 volts then it still could be either board.
I personally would replace the display board first as other control board functions do work.
In any case it is a bit of a crap shoot.
If you order the board from AppliancePartsPros and it does not fix your problem they will allow you to return the board.
Please see their return policy.
Davidf2010
#4 Posted : Thursday, August 12, 2010 2:24:48 PM(UTC)
Davidf2010
Great! Thanks for your reply! I'll try your suggestions and report back!
