ccondon23
#1 Posted : Sunday, March 14, 2010 7:53:58 AM(UTC)
ccondon23
My dryer no longer dries a load in one cycle, regardless of whether I use a timed cycle or the moisture sensor cycles. Typically, I need to run the load for about 30 minutes after running a full (70 minute) cycle.
I've check the exhaust hose and it is clear. I ran the dryer empty for a few minutes and the air coming from the exhaust feels hot enough (i.e., it is amost hot enough to burn your hand).
Any ideas?
ccondon23
#2 Posted : Sunday, March 14, 2010 7:55:47 AM(UTC)
ccondon23
I forgot to mention that the drum does spin.
