nd (not draining error) this model doesn't have the debris filter as in some models behind a small door. Got the water to drain out manually. can't find a part number for the pump. is there a way to test to see if its the motor or the pump itself. I have the pump assembly out. Please help! Thank you.:confused:
Originally Posted by: nick creekmur  nd (not draining error) this model doesn't have the debris filter as in some models behind a small door. Got the water to drain out manually. can't find a part number for the pump. is there a way to test to see if its the motor or the pump itself. I have the pump assembly out. Please help! Thank you.:confused: I took the pump apart and there was a matchstick preventing the impellor from moving. Removed it and reassembled. It works fine so far! I hope this helps someone else.
Think Io might have the same problem. How do I get the pump out??
Thanks.
I am having the same problem with my Samsung WF316LAS/XXA. I have replaced the drain pump and it still doesn't work. Does anyone know what could be wrong?
