mdevour
#1 Posted : Saturday, March 13, 2010 11:10:39 AM(UTC)
mdevour
Our Maytag DWU8260AAX has been a workhorse for a lot of years. I'm trying to stretch it out a few more months, since we'll be leaving it behind when we move and the new house already has an 18" unit.
I am an electronic technician, so please assume I have basic competency with electricity and test gear.
The soap door has stopped opening automatically. I've taken out the wax motors and attempted to test them. Am I right in thinking that if I hook up a cheater cord to the connector and plug it into the wall, that the end of the unit should get warm and the plunger should extend at least an extra 1/4" or so? If so, they're both dead.
One measures ~60k ohms, the other >350k ohms...
Here's the part:
http://www.appliancepartspros.com/part_details.aspx?part_id=4110779ℑ=0
We never use a rinse aid, so should I be able to get away with just replacing the one for the soap door?
Thank you,
Mike D.
#2 Posted : Sunday, March 14, 2010 1:19:11 AM(UTC)
This should help see page 1-5
http://www.servicematters.com/maytag_library/docs/16007823.pdf
Yes you could replace just one if you want.
mdevour
#3 Posted : Monday, March 15, 2010 2:50:23 PM(UTC)
mdevour
Thanks, Denman. I've put it back together and will test with tonight's load of dishes.
Thanks for the link to the service manual. I tried searching at that site to get to the same link via my model number and can't seem to get there. Is there a trick?
http://www.servicematters.com/m...ibrary/docs/16007823.pdf
#4 Posted : Monday, March 15, 2010 3:31:00 PM(UTC)
I[COLOR="Blue"]s there a trick?[/COLOR]
Not that I know of
Seeking help with 2nd bad control board & "wax motors"? (Washer Repair)
by gowestwardho 8/21/2016 5:44:18 PM(UTC)
