madmex65
#1 Posted : Friday, March 12, 2010 5:03:23 PM(UTC)
madmex65
My dryer won't heat. I have replace the heating element and sensor with not luck. Any advice to possible problem and solution.
#2 Posted : Saturday, March 13, 2010 12:24:33 AM(UTC)
Replacement parts for WHIRLPOOL GEX9868JQ3 29" Electric Dryer | AppliancePartsPros.com
Note: That I could not find a JQ8 so am assuming that it is actually a JQ3.
Here is the tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Tech%20Sheet%20-%208535880.pdf
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 10 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
Note: That the thermal fuse for the heater is the one by the heater. The one for the motor is the one on the blower.
If the heater fuse is blown there are things you have to check before replacing it to increase the odds that it will not blow again.
