lorainejohnson
#1 Posted : Friday, March 12, 2010 9:38:41 AM(UTC)
lorainejohnson
My dryer heats up way too hot and it won't do the cool down cycle. What thermostat does it need and does it need anything else besides that?
#2 Posted : Saturday, March 13, 2010 2:01:18 AM(UTC)
Replacement parts for MAYTAG MDE9206AYW Dryer - Ele | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/maytag_library/docs/16023086.pdf
It could be a number of things.
That it will not do a cool down at the end of a cycle points to a grounded element as this function is controlled by the timer and not a thermostat.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
