Replacement parts for MAYTAG MCG8000AWW Dryer Cabinet - Gas | AppliancePartsPros.comHere is a manual which should help trouble shoot it.
http://www.servicematters.com/maytag_library/docs/16022785.pdf[COLOR="Blue"]The membrane is slightly worn over the start button but it does click when pressed.[/COLOR]
This does sort of point toward the console/keypad.
Check the switch at the ribbon cable with a meter, see the manual.
If the switch closes consistently then it is probably the control board.
If the switch closes intermittently then it is the console/keypad.
Also you may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
