2 Pages12>
howdyadothat
#1 Posted : Friday, May 23, 2008 6:42:10 AM(UTC)
howdyadothat
I have a whirlpool top load direct drive ultimate care II washer and it does not high speed spin. I have checked the coupling and it appears to be okay. The water pumps out, put the clothes remain wet. It will sometimes high speed spin if I unload most of the wet clothes.:confused:
SublimeMasterJW
#2 Posted : Friday, May 23, 2008 6:59:09 PM(UTC)
SublimeMasterJW
Remove agitator(1 bolt)
then remove tranny( 3 bolts )
the clutch is mounted on top the tranny.
SublimeMasterJW attached the following image(s):
fyxer
#3 Posted : Saturday, May 24, 2008 2:11:53 AM(UTC)
fyxer
I had a problem like this a few months ago it was caused by a worn basket drive block---part number --389140.
Fyxer - Hot Hubs
#4 Posted : Saturday, May 24, 2008 2:25:29 AM(UTC)
Before removing tranny, turn the tranny coupler clockwise till the spin basket starts to turn. If hard to turn the coupler, you have dragging brake shoes causing the slow spin.
howdyadothat
#5 Posted : Saturday, May 24, 2008 10:33:26 AM(UTC)
howdyadothat
It is very difficult to spin. Does it matter what the setting is? I noticed that it was not set to off. I tried to spin the basket and it spins with difficulty also. There is a light residue of oil sprayed around the inside of the machine case about even with the tranny.
SublimeMasterJW
#6 Posted : Saturday, May 24, 2008 11:25:32 AM(UTC)
SublimeMasterJW
the next thing to do is remove the agitator and then the tranny and inspect this:new-fuses.jpgThe little ear will wear down or break off or their will be brakes locked up as mentioned before.
howdyadothat
#7 Posted : Monday, May 26, 2008 6:22:52 AM(UTC)
howdyadothat
I did not notice any of the ears breaking off. There is no apparent damage to this area of the machine. This picture in the attachment is not very good, but maybe it can help. I tried to move the assembly around, but when I did it dropped out of the casing a little. Is there a way to get it re-aligned? Where do I look for binding?Home 051.jpg
Thanks for your help.
howdyadothat attached the following image(s):
#8 Posted : Monday, May 26, 2008 6:50:09 AM(UTC)
Go to my thread in the general talk section, page 4 "replacing brake shoes"
SublimeMasterJW
#9 Posted : Monday, May 26, 2008 9:33:50 AM(UTC)
SublimeMasterJW
I cannot seem to find your page. I would like to read that.
#10 Posted : Monday, May 26, 2008 10:10:10 AM(UTC)
Don't know how to transfer post! Go to general talk section, page four "replacing direct drive washer brake shoes", the 5 star post.
2 Pages12>
