Icemaker chute keeps freezing up. I'm trying to take the door apart to replace the chute door and spring. Not sure how i'm supposed to gain access to do this. Any help out there. Do I have to take the door apart from the inside?
Originally Posted by: strictlytires  Icemaker chute keeps freezing up. I'm trying to take the door apart to replace the chute door and spring. Not sure how i'm supposed to gain access to do this. Any help out there. Do I have to take the door apart from the inside? Just a quick note... I just got it. the black trim comes off, then the control head, and then the lever. The spring to the flapper door had come off. Just a quick adjustment and the spring is back in place. Hope this helps someone.
