fvetampa
#1 Posted : Saturday, August 25, 2007 11:05:07 AM(UTC)
fvetampa
My Side by side is accumulating ice on the floor of the freezer. Does anyone know why?
#2 Posted : Monday, August 27, 2007 11:03:20 AM(UTC)
Hi fvetampa
Most likely the problem with your fridge is a clogged and frozen up drain.
The drain is located on the bottom under the rear panel inside the freezer. You can use a hair dryer to defrost the drain and a few cups of hot water to run through.
- For the future references here are the break down diagrams for the Maytag refrigerator Model MSD2454GRW
Good luck.
