I have a Maytag dishwasher that gives off an electrical smell when it runs and then won't rinse during the rinse portion. Even though the timer continues it wont drain the water. I have to turn it off and wait for it to drain any water. The fill valve is working but it will not drain or rinse. Any idea's.
Sounds like the problem is a bad motor. What is the complete model number of the dishwasher?
The model number is dwu9200aax serial number a9929574mb
The motor comes as a part of the pump & motor assembly. If you know how to handle a simple tools, this part is not too difficult to replace yourself. - The pump & motor assembly Part number: AP4371966
