dcalthetiger
#1 Posted : Tuesday, March 9, 2010 10:31:13 AM(UTC)
dcalthetiger
Oven would just heat on the broiler element and would not shut off. Had to turn the breaker off. It gave me a code of F3 E2. I checked the sensor connection and it was fine. I ohmed the sensor and it was ok according to the tech sheet. The only thing left is a welded-closed relay. Now if I am correct on this it would mean that I would have to replace the control panel. If so I am wondering if it is worth spending that much on an oven that is 10 yrs. old?
magician59
#2 Posted : Tuesday, March 9, 2010 11:06:47 AM(UTC)
magician59
Weigh the cost of a $200 part against that of a new oven...How attached to the old one are you?
