ladyengineer
#1 Posted : Wednesday, May 21, 2008 8:11:49 AM(UTC)
ladyengineer
My Kenmore dryer will stop itself and beep 3 times at random intervals when I try to use the "time dry" setting. The same thing happens when I use the sensor drying setting. It will turn itself off, let out 3 beeps, and rapidly use up any remaining time left in the cycle to settle back to "off". It doesn't seem to matter what size the load is or what setting I use (except no-heat seems to complete it's cycle). I have cleaned out all the lint I can get to, but it didn't help. Any suggestions?
papagary
#2 Posted : Tuesday, July 15, 2008 1:17:24 PM(UTC)
papagary
Mine Kenmore has the same symptoms, however, I switch it to ‘OFF’ and let it reset for a second it works for another 5-10 minutes. Does anybody have a solution? Up to this point I have cleaned all of the venting pipes and I temporary removed the ‘High limit thermostat from the ‘Burner funnel’ and it still has the same problem.
Any info would be helpful
