I have a GE JGSP22 range thats been acting up for the past couple of days. When we ignite any one of the top burners the electronic control panel (for the oven) lights up (like it just lost power) and the time resets. All of the functions work properly. Thanks in advance.
UPDATE: I pulled the range out of the cabinent and tried to plug it in another outlet and it worked fine. I then plugged it back into the original outlet, making sure it it totally in, and the unit works fine now. I guess that somehow the plug came partially out and was causing the issue.
