Earl Dryer
#1 Posted : Tuesday, May 20, 2008 5:03:38 PM(UTC)
Earl Dryer
On oven control, push bake & start, a 10 minute warm-up starts with the igniter glowing brightly, at the end of the 10 min. the timer dings and the display shows 350 deg temperature setting, but no ignition. Waited a couple more minutes and still nothing. Unplugged the range to see if it would reset it's self (5 Min) then tried again with same results. After a few minutes, I tried the old Army trick and tapped on the oven valve and behold there was ignition. Was this coinsidence or is the valve defective.
#2 Posted : Wednesday, May 21, 2008 1:20:10 PM(UTC)
Earl,
Measure the current drawn by the oven igniter. If it more than 3.2 amps then the problem is a bad gas valve. If it's 3.2 amps or less then the problem is a bad igniter.
- The part number for the oven igniter is AP3129373
- The part number for the gas safety valve is AP3129369
Here are the break down diagrams for the Whirlpool range Model SF315PEKB0
