Previously posted about a problem that I repaired with a new gas valve. Now the oven/broiler will light once and stay lit for 10-15 seconds on go off not light again unless I unplug the range turn the gas off then plug it in and turn the gas back on. Then the whole process repeats its self. Previously the oven/broiler would not even try to light. Found the ohms on the broiler side of the gas valve was 0 and the oven side was 198. But like I said the valve was replaced. Now what?
the same problems and more. I called a repairman and he had absolutely n o ideas. He basically admitted he was guessing. Let me know what you find out.
Originally Posted by: jamesrescue1  Previously posted about a problem that I repaired with a new gas valve. Now the oven/broiler will light once and stay lit for 10-15 seconds on go off not light again unless I unplug the range turn the gas off then plug it in and turn the gas back on. Then the whole process repeats its self. Previously the oven/broiler would not even try to light. Found the ohms on the broiler side of the gas valve was 0 and the oven side was 198. But like I said the valve was replaced. Now what? Hi James. Wondering if you ever got to the root of the issue. My oven burners do exactly the same thing.
