magngineer
#1 Posted : 17 years ago
magngineer
Does anybody have any experience with removing an old garbage disposer with the brand name "National" on it? It may have been made by or was a division of Hobart. The rating label is faded and hard to read. I think this unit may be over 30 years old.
It has a mounting ring on it like most disposers, but doesn't look like it was designed to be rotated in place like most units. I could be wrong because it has a heavy wire "lever" sticking out the side of the mounting collar. I have tried to rotate it by this lever but it won't budge. I have not tried to rotate it REAL hard for fear of breaking off this lever. I can post a pic of it if it would be helpful
Any help would be appreciated.
#2 Posted : 17 years ago
A pictures might help.
magngineer
#3 Posted : 17 years ago
magngineer
Here's a pic of the mounting ring. Hope the picture come through.
magngineer
#4 Posted : 17 years ago
magngineer
I think the picture was too large pixel wise. Here is a resized version.
File Attachment(s):
#5 Posted : 17 years ago
Unscrew the nut shown on the attached picture. It should be two more around.
Gene attached the following image(s):
magngineer
#6 Posted : 17 years ago
magngineer
Thanks Gene. Do you know what the lever with the red cap if for?
#7 Posted : 17 years ago
Looks like a handle.
