Anyone know how to remove the door handle on the fresh food side of a JennAir JSD2588AEW refrigerator? The back side of the handle has a crack in it and needs replaced. How do you get to the screws holding the handle to the door? Thanks for your help.
If it is a plastic handle face, gently pry it free from the frame to expose the screws.
Originally Posted by: magician59  If it is a plastic handle face, gently pry it free from the frame to expose the screws. Magician59: Tried your recommendation and it worked great! Was able to take the handle apart and replace the broken piece. Thanks for your help, I appreciate it. stemwinder
Glad to help. Always good to help someone avoid a costly service call.
