turtle99
#1 Posted : Tuesday, May 20, 2008 5:47:43 AM(UTC)
turtle99
I started the oven on self cleaning mode. After the cleaning was done, the oven door stayed locked, and an F9 error is showing. There is no information in my manual on what this means. Can someone help me?
#2 Posted : Tuesday, May 20, 2008 7:10:32 PM(UTC)
The "F9" error code means the microprocessor has found the lock motor switches to be out of sequence or shorted. Test switches and if found to be good and in proper sequence then replace the Electronic Oven Control.
The model number you posted does not come up (it is a Canadian model)and I'm not able to provide more accurate information.
