shareefhart
#1 Posted : Saturday, March 6, 2010 12:43:22 PM(UTC)
shareefhart
You have been a member since:: 3/6/2010(UTC)
Hello my dryer no longer spins. I am not sure if it is the belt or the motor that needs to be changed. The heat still comes on but that is it. I am looking to order the part and repair it myself, unless you suggest otherwise. Thank you for your help in advance. shareefhart@yahoo.com
bran9192
#2 Posted : Sunday, March 7, 2010 5:15:37 AM(UTC)
bran9192
I'm having this same problem. Open the dryer door and hold the tab that is pressed when the dryer door is closed and you should hear the motor kick in when you turn the dryer on/off.
Dryer does not spin (Dryer Repair)
by nospin 1/5/2008 4:31:49 PM(UTC)
