AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Replacing lid switch on Whirlpool (Kirkland) Washer
Have a broken lid switch. It looks like your part # AP3100003. First, it that a suitable replacement? Second, how easy is it to connect to the control panel?
The lid switch is OEM part made by Whirlpool: Part number: AP3100003
It is pretty simple to connect the new switch electrically - just open the control panel and you'll see how it plugs in. You have to remove the washer cabinet to replace the lid switch. The video above shows step by step instructions. Here are the break down diagrams for the Kirkland (Whirlpool) washer Model SAWS800MQ0 Gene.
Hi Gene So sorry it has taken so long to get back... Model SAWX650JQ0 Washer bought at Cosco(Kirkland made by Whirlpool) it will fill and aggitate in beginning but will not drain or spin....took top off to expose switches please help asap if you can...really and truly appreciate jeannie
Thank you so very much for your help and diagrams....could not have done it without your knowledge...and you saved us a ton on money and heart ache...It worked!!!!!!! and best of all "IT" works !!!! Between my husband and myself we managed to get r done =) the crafts
You are welcome. I'm glad you were able to fix it.
Hi Jerry, You can find the instructions attached to this reply. Gene.
Thanks for the info. Here is an article I found on washer switch repair and the dangers associated with it.
Dishwasher Repair
