dryer stopped , light does not work where can i locate the 30 amp fuse to check?
Originally Posted by: tmp@i-55.com  dryer stopped , light does not work where can i locate the 30 amp fuse to check? for admiral dryer model # LNC7764A71
If you have a meter, you can check for voltage at the outlet.
