How does the yoke (part AP4072309) for the ice depenser motor (part AP4009036) attach to the motor shaft. My yoke spins freely on the shaft so that when the shaft turns the yoke doesn't. Is the yoke suppose to be threaded or should there be a nut holding it to the shaft. Thanks
It is threaded onto the shaft. (I think it's reverse-threaded) If it's stripped, you should replace both the motor and the yoke.
