George Handte
#1 Posted : Monday, May 19, 2008 1:20:19 PM(UTC)
George Handte
I received part WR57X10012 but instead of having push disconects for the output valves it has threaded connectors I need the nuts for these. one is for a 1/4 inch plastic line the other is for a 3/16 plastic line. Your picture of the part shows it with the the push disconnects. I talked to your salesman but he couldn't help. Do you know where I can get the compression nuts for this fitting
#2 Posted : Tuesday, May 20, 2008 1:14:28 AM(UTC)
My book shows compression fittings. You can buy these at Lowe's. This valve is better than the quick disconnect type as you can always replace the lines if they go bad.
help with GE water valve assy (Refrigerator & Freezer Repair)
by rbuzz 8/18/2008 7:47:58 AM(UTC)
