About a month ago my ref start gettin warm. The freezer wasn.t cooling properly. I noticed their was frost in the freezer. I took the inside panel off and thawed out the coils. Everything worked fine until a day ago. The frost is back and the ref and freezer is not cooling. Can you help me with this problem. George
You have a defrost failure. Most likely the defrost heater is burnt out.
