nexparich
#1 Posted : Monday, May 19, 2008 11:41:28 AM(UTC)
nexparich
My electric wall oven heats up to the desired temperature, and then turns off, and does not heat up again to maintain desired oven temperature. I have replaced the heating element already. Could it be the thermostate?
The 11 year old oven has a thermostate with 4 prongs for wires to be plugged into it. The model number on the oven Magic chef (9512wjv) is not listed, or at least I can't find it. The computer suggests I check the model #9512wuv which has a thermostate with only 2 prongs for plug ins wires.
Should I keep rying to repair this, or just replace the oven ? Thanks
#2 Posted : Tuesday, May 20, 2008 12:13:25 PM(UTC)
Call the Appliance Parts Pros customer service (877-477-7278) and ask for Adam.
