DDD
#1 Posted : Wednesday, March 3, 2010 5:17:29 PM(UTC)
DDD
I accidentally :oput liquid Dawn dish soap in the 'RINSE' dispenser of my Triton XL dishwasher. Could somebody tell me if there is a secret to getting it out of there?? If I have to remove the front panel to do it could someone please tell me exactly what needs to be done to remove all the soap? I realized what I had done and I have NOT run the dishwasher since I did that dumb thing. :o thanks
#2 Posted : Friday, March 5, 2010 12:36:08 AM(UTC)
Here your parts
Replacement parts for General Electric GSD6200G00WW Dishwasher | AppliancePartsPros.com
Probably the fastest way to clear it is to remove the dispenser from the machine, pour out the soap and then rinse it out with warm water.
You will have to do this numerous times, till there is no hint of bubbles when the dispenser is half filled with water and then shaken and emptied.
It does not take much dish soap to cause a huge amount of bubbles.
Alternatively you could use a turkey baster or similar device to suck out the soap. Then fill with water and redo this. Problem is it will take forever to get it cleaned out.
DDD
#3 Posted : Friday, March 5, 2010 2:31:32 PM(UTC)
DDD
Thanks Denman! The baster thing didn't work because the needle just didn't reach the soap, but you gave me the confidence to GO IN & take it apart & clean it out! Thanks again for being the only one to offer me help with something that happens everyday in homes & we are told to purchase & replace the soap/rinse module when that is just not necessary. :)
