My G.e. Dishwashers Control Panel Dose Not Light Up And Will Not Show What Mode Its Running In,or Time,some Times It Wont Work For A Day Sometime Three Days And Some Times Will Not Work At All,something Going To Let Go How Do I Go About Repairing That Mane Panel,so It Shows Lenth Of Wash Heated Dry, Short Wash,upper Rack,pots And Pans And So Forth, Thank You Tony,
Here is the parts breakdown Replacement parts for General Electric PDW8900L00BB Dishwasher | AppliancePartsPros.comGot very lucky and was able to find a manual http://appliancejunk.com/ge/dishwasher/31-9137.pdfI would try the following first as it sounds like a dirty/intermittent/loose connection Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try. |
THIS FORUM IS DEAD!!!!!!! |
