1. Start the dryer 2. Igniter turns into red and then brighter 3. Blue fire starts, for about 3 minutes, it shuts 4. Even though the igniter lights again, it doesn't start blue gas fire. 5. Stop machine and start again, steps 2 and 3 repeat again When the machine cools, it starts gas fire again. But the cloth is not hot enough to dry. It eventually dry by air flow. We clean the vent and machine dust. If the coil valve is the problem, part number AP3094251 is the correct part?
We replaced coil valve and it works.
