jzeni
#1 Posted : Tuesday, March 2, 2010 5:25:27 PM(UTC)
jzeni
i have a problem with the blower not running. it will rock back and forth or possibly make 1 revolution for several cycles in a row. occasionally it will start and the gas valve will open. it did then shut down in about 10 seconds but i had the door off so i assume it was from the over limit switch in the tube. i believe the motor to be ok since it can run. i also do not get an error code when i push my cycles and help buttons. i cant seem to locate a repair manual so i'd appreciate any troubleshooting tips.
thanks
sidfink43
#2 Posted : Saturday, March 6, 2010 5:08:22 PM(UTC)
sidfink43
Here is a repair manual from another site
http://www.affordableappliance....der/GE_Harmony_Dryer.pdf
jzeni
#3 Posted : Saturday, March 13, 2010 6:13:50 PM(UTC)
jzeni
thank you sidfink43. i downloaded the manual and will be able to use it to diagnose. you see, when i put the machine back together it worked normally as it did last time i had the same problem. now though il have a place to start.
jzeni
#4 Posted : Thursday, March 18, 2010 10:05:26 AM(UTC)
jzeni
well the dryer is out again but this time my error code is the "blower is not getting up to speed". this leaves me with 2 possible problems. replace the blower motor or the inverter. the motor winding check out and there is no way that i see to check the inverter. any ideas?
sidfink43
#5 Posted : Thursday, March 18, 2010 11:28:53 AM(UTC)
sidfink43
Can't really say except the electronics are usually the culprit.
