AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer will fill, however, doesn't agitate or spin out - just "clicks".
Yesterday, the machine was fine. Today, I filled it (small tub) but it would not agitate. I checked to see if it would spin (did not) therefore, will not empty. It just "clicks" as it does when timing to next cycle, but nothing happens.
The serial #, I believe, is on the back of the machine, and I cannot move it to find it. Will this make it more difficult to select part #?
Originally Posted by: dottiedd Yesterday, the machine was fine. Today, I filled it (small tub) but it would not agitate. I checked to see if it would spin (did not) therefore, will not empty. It just "clicks" as it does when timing to next cycle, but nothing happens.
The serial #, I believe, is on the back of the machine, and I cannot move it to find it. Will this make it more difficult to select part #? ** The serial # is 435092, Model A510, Series 01
Washer Repair
