rgirrbach
#1 Posted : Monday, March 1, 2010 6:13:09 AM(UTC)
rgirrbach
I Already Had This Frig Worked On, About Five Years Ago. It Is Now Doing The Same Thing It Did Then. The Freezer Frosts Up And Doesn't Defrost, Without Help. The Freezer And Frig Do Not Get Cold. I Do Believe It Was A Defrost Thermostat Or Something. I Can Not Afford To Have It Repaired, Would Like To Do So Myself. Can You Tell Me What Part It Would Be? From What I Have Seen, It Is A Very Common Problem With Them. Thank You
txrott
#2 Posted : Monday, March 1, 2010 7:31:07 AM(UTC)
txrott
Here is the defrost thermostat# AP4002415
#3 Posted : Tuesday, March 2, 2010 3:16:02 AM(UTC)
Replacement parts for AMANA BR18VL Ref - Bottom Mounts | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/maytag_library/docs/T12012R1.pdf
And a manual
http://www.servicematters.com/maytag_library/docs/S120_4R.pdf
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 342 in Section 10) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item in Section ) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item in Section ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
