I just noticed that I have water leaking from the front of the dishwasher. It appears that while the dishwasher is running, I see water intermittently splashing over the front lip of the tub. I have been doing some research and I have come across others with the same problem. Mentioned in an article was tightening down several torx screws on the top of the pump assembly, which would supposedly eliminate leakage and prevent tidal action of the water at the bottom of the tub from sloshing over the front lip. Should I try this or would you have any other suggestions?
Thank you, Jon Gordon
Check the condition of the door seal. If it's dirty, cleaning it will help reduce the leaking. If it has gone too long, replacement will be necessary.
