Just bought a used dryer (Maytag MDG3000AWA, Gas). Pulled our my old Kenmore dryer to make way for the Maytag. The dryer worked at the sellers, but after I moved it and hooked it up at my place, it doesn't work at all. The interior light is not even on. Seem like I knocked something loose in transit.
Where to start?
Have You Checked The Power Cord? Make Sure You Are Getting 110 To It? Check Breaker And Wall Outlet , Then Back Of Pigtail.
I have 110V at the receptacle (wall outlet). Is it possible the hot & neutral are reversed where the cord connects to the dryer?
Are you getting 110 where it comes in to the dryer? Where the pigtail attach's?
Where do I check? Do I need to take the front panel off?
No. Its at the back of the dryer where the power cord go's in. Should be a plate there where it attaches to dryer.
I have 110vac at the timer motor, where the pigtail terminates. I unplugged the unit and checked the thermal fuse: zero ohms. Checked the door switch for continuity: ok.
What next?
I reversed the leads on the pigtail. Butta-bing, the dryer now works.
