There are four knobs that control the clock for my oven. Two are snapped off. All the other knobs, i. e. temperature, etc., pull off to free the glass panel, except the four clock knobs (two of which I want to replace). Any suggestions on how to remove the glass panel in order to remove the clock? The four screws that attach the clock are behind the glass panel.
These knobs are "push in" and you have to pull them to remove. There is very high risk to break the knob and then you will have to replace the whole clock which is no longer available. Here are the break down diagrams for the Magic Chef oven Model 59E-5EXWGene.
