AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer still does not heat. Where are the Thermostats
Hello,
I have replaced the igniter an coils. Where are the thermostats located and what is the part number? Thank You!
Best Regards,
Mike:mad:
Mike, Have you checked the thermal fuse (#6 on the diagram) for continuity? If it's open, it has to be replaced together with the cycling thermostat (#7). - The thermal fuse Part number: AP3132867
Dryer Repair
