I have an Electrolux Frigidaire electric glass top range with 4 burners. The largest element burner will not turn off. Burner stays on high when it is pointed to Off or even Low
Most likely the problem is a bad power board which is located on the main back of the range. - The part number for the power board is AP2126657 Gene.
