I ordered new start relay for my fridge asd2514arw and the wiring is diffrent from oem part. This relay has three posts 2 left one right, The oem had 2 posts one left one right. On the oem the orange wire from the capacitor and the orange from the power were connected to one terminal. My question is which post does the wire from the capacitor go to on the left side the top or the bottom?
Look at the compressor pins, they are positioned in a triangle configuration.. If one is on top, and two on the bottom, the top terminal is the common one and the bottom two are start and run windings. The two run capacitor wires atach to these two bottom pins. The two terminals on the left are probably shorted together. When you plug in the black start relay, you plug in the capacitor wires between the left and right terminols.
