I have water coming out from under the bottom but cannot fing any leak. Suggestions, please???
Check the door seals especially around the corners. Any bunched up door seals will allow for air to get into the ice box and form condensation. The drain pan may have a hole in it. Sometimes the drain gets stopped up and the water cascades down under the bottom drawers and out the front. The water solenoid can get a faucet like drip.
