The drum wont spin. Makes a noise like the motor wants to spin but wont. Removed the drum and tried to start it and the same thing happened, but when i spun the motor by hand it started to go by itself. Do I need a new motor?:confused: Thanks for reading.:)
Sounds like a weak motor. You may want to see if vacuuming all the lint and dust out of the motor helps.
Thanks for your help. still dont work so iguess i will get a new one thank you again:):)
