Please advise how difficult it is to repair a top over door Hinge on a Frigidarie in wall oven? :(
Can you be more specific on the problem?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Can you be more specific on the problem?
Gene. Hello, Yes I have a dual oven.. on the top oven . The Left hinge is bent and the door sticks.. It has a roller and the arm of the hinge sticks .. I have ordered a replacement for the hinge.. My question is how difficult is it to replace the hinge.. It it mounted on the base fo the oven with 2 screws..
This part is not too difficult to replace yourself. Remove these two screws and pull the old hinge. Be careful not to loose the spring.
