Kenmore Model Number 25378299895
Part # 215216648. This one is no longer available
Is there a compatible part?
Thank you
This part has been replaced with part # 215216634 Make sure that is the correct part you need, at $141, best to check. If the trim is busted, you might want to fix it with nylon packing tape.
Thank you for the information. :) Right now the front corner where it joins the support plate, is completely busted...The top is sitting in top of the crisper drawer. Not an inexpensive repair for sure.
Thank you!
