Had power surge, Now dryer gives E61 error code. Have 220 coming in. Have reset breakers and Dont know what else to try now.. Any Help?
GE is very tight with technical info and I do not have any service manuals on this model. Look inside the console and see if you can find some tech notes which will explain the error code and allow you to do some testing.
There is a wiring plan.. but no error code list..
Well, that is unusual, but as I said, they are very close with their technical data. Maybe someone else has some tech sheets for this model and will chime in.
One can only hope... read somewhere it was main control board..
Fixxed Problem Myself... Main control board needed replaced... E61 is code for improper voltage was sensed between neutral and hot.
Great, glad you got it fixed and thanks for the update.
Thank You for your assistance.
