kfridge
#1 Posted : Tuesday, February 23, 2010 9:55:39 AM(UTC)
kfridge
A few days ago my refrigerator started to rattle loudly as it cycles off. Is the refrigerant low? Is the compressor failing?
#2 Posted : Wednesday, February 24, 2010 4:57:35 AM(UTC)
Here is your wiring diagram
http://www.servicematters.com/d...0Sheet%20-%202201079.pdf
[COLOR="Blue"]Is the refrigerant low?[/COLOR]
I doubt it as you would notice the freezer not getting to the correct temperatures.
[COLOR="Blue"] Is the compressor failing?[/COLOR]
Could be though usually it is more of a bang.
Remove the back panel and check where the noise is coming from.
Could be a bad motor mount, may also be the condenser fan rattling as it slows to a stop.
