Need help with gas range oven on bake not maintaining temperature. Tested @ 350 heats up and says it is 350 after 15 minutes but when turn it off & on right away says it is really only 300. Tested @ 400 heats up and says it is 400 after 15 minutes but when turn it off & on right away says it is really only 350
Any assistance is greatly appreciated.
Don
GE Model JGB920WECWW
Are you getting those readings from an external thermometer, or reading them from the display?
Hi ,
Thanks for the reply,
The temp is coming from the stove display.
Best,
Don
